KonanGod
Jun 27, 2020Follower
Wifi Extender Only Works for a Couple of Minutes
I recently purchased a EX6110 Wifi Ranger Extender and have gone through setting it up multiple different times in multiple different ways and yet everytime I get it set up, the thing has all green lights and works fine for about 2 minutes before quitting for a while then coming back on. It doesn't matter where I put it, it does the same thing. I'm on CenturyLink using a C1100T router if that helps in any way.
Edit: Almost forgot to mention that I have already checked the firmware, and yes it's at the current firmware. I've even overwritten it with the file from netgear still to no avail.
- Chris205Aspirant
Did you make sure the IP address the extender is using is a static IP address, not getting one from DHCP? I found that worked for me with my EX6250. You'll need to choose a static IP address through your router.
- CoaleyedGuide
If you start messing with static IPs make sure that you go into your router and change the scope of DHCP so that it never gives it to something else if the router restarts.
ie.
192.168.1.1 is default to start handing out addresses
change it to
192.168.1.5
Then static IP the box as suggested to something like 192.168.1.3
It also won't hurt to go into the router and block that MAC address to that 192.168.1.3 so that when it comes back the router knows what to do with it instantly.
Hopefully the combination of the posts here helps you out.
