jfish303
May 10, 2016Aspirant
Wifi Extender or Access Point
I want to extend my network. I'm wondering if I need a range extender or wireless access point. I plan to plug either device into the main router via ethernet cable. I'd like as little speed degredation as possible. I am using a nighthawk router.
Thanks for the help
- VE6CGXMaster
If you can run a cable AP is the choice.
- jfish303Aspirant
One more question. Am I better using the newer nighthawk as the main router and the wndr4000 as an AP or would it be better the other way around? The main router will be in a utility room while the AP will handle most of the wireless connections
- VE6CGXMaster
I'd always put better router at the front. So far I have been covering my whole house with just one router but when if I had to deploy AP
that's what I'll do.
