Brandon22175
Jul 23, 2020Aspirant
WiFi Extender Password EX3110
I am trying to connect to my Wifi extender and it is asking for a password. I dont see a password on back of device and it will not accept my router password.
- Jul 23, 2020
I would install using the installation wizard and NOT wps.
Brandon22175
how do I do the factory reset? There is a button on the side for reset but nothing comes up on my computer in terms of instructions when I hit it. or a installation wizard?
Jul 23, 2020Guru - Experienced User
To reset you have to push and hold the reset for 7-15 seconds while its powered on. That'll get it back to defaults.
The manual has instructions for using the installation wizard. The guide also has these. you can find both here:
https://www.netgear.com/support/product/EX3110.aspx
- Brandon22175Jul 23, 2020Aspirant
great thank you, and to be clear, install using WPS or not WPS?
- plemansJul 23, 2020Guru - Experienced User
