LIDA7065's avatar
Dec 26, 2020
WiFi Extender recommendation
I'm looking for a recommendation for a WiFi signal extender. In my basement, I have a SiriusXM radio that keeps dropping it's signal. I was looking online and I saw an EX5000 and an AC1200 but I don'...
  • plemans's avatar
    Dec 27, 2020
    I usually recommend triband extenders. Standard extenders (single/dual) take a 50% speed hit because of how they operate. Tribands don't take this hit as they have a dedicated wired backhaul.
    The RBS40V has extender mode and can usually be found on sale for the top of your price range. or most of the other dual bands should work.
    The GDI-SXTTR2 is a single band and not dual band, fyi.
    You can try changing the channel your broadcasting on as 2.4ghz is more sensitive to interference.
