LIDA7065
Dec 26, 2020Tutor
WiFi Extender recommendation
I'm looking for a recommendation for a WiFi signal extender. In my basement, I have a SiriusXM radio that keeps dropping it's signal. I was looking online and I saw an EX5000 and an AC1200 but I don'...
- Dec 27, 2020
I usually recommend triband extenders. Standard extenders (single/dual) take a 50% speed hit because of how they operate. Tribands don't take this hit as they have a dedicated wired backhaul.
The RBS40V has extender mode and can usually be found on sale for the top of your price range. or most of the other dual bands should work.
The GDI-SXTTR2 is a single band and not dual band, fyi.
You can try changing the channel your broadcasting on as 2.4ghz is more sensitive to interference.
LIDA7065
Dec 27, 2020Tutor
It is a dual band router
Walls are blueboard & plaster
Grace Digital Model #GDI-SXTTR2
Budget $20 to $100
Most of the house is fine, just one flakey spot in the basement.
Dec 27, 2020Guru - Experienced User
- LIDA7065Dec 27, 2020Tutor
Many thanks for your help, it was much appreciated.
