mwfraser
Mar 10, 2013Follower
WIFI Extender setup - "Generate Keys"?
Have you setup a WN3000 using a Windows 7 (home Premium) computer? I tried to follow the primer offered by Netgear, but the windows it showed differ from mine - On the window where I enter the WEP Ke...
jmizoguchi
Mar 11, 2013Virtuoso
Use WPA2 instead of hackable WEP on main wireless router
You can use ANY of generate for WEP (ex. Key 1 chosen on main router)
