Samytt
Aug 13, 2024Aspirant
WiFi extender upload speed is very slow
My wifi router (rax120) speed is not bad. download 600 mbps upload 700 mbps but my WiFi extender(eax80) upload speed is very slow. download 400 mbps upload 60 mbps I don’t know the reaso...
Aug 14, 2024Guru - Experienced User
Your download is right where we expect it but not your upload.
reason why is the EAX80 is a dual band extender. And it has to use the same channels to go router---extender and extender----device and it can't do both at once. so it cuts throughput in half. so that download is pretty spot on.
Its just the upload that needs working on. It almost seems as if its using the 2.4ghz for the upload.
did you set it up with WPS? Or the installation assistant?
How are you testing speeds?
What speeds do you get hardwired into the extender?
got a copy of the status page?
- SamyttAug 14, 2024Aspirant
Thank you for your reply.
I set up installation assistant.
I attached my WiFi extender screenshot.My WiFi extender hardwired speed is
Download is 781 mbps
Upload is 74.0 mbps- plemansAug 14, 2024Guru - Experienced User
Is that a hardwired connection?
What device are you testing on?
Have you tried a different device?
Or tried a different speedtest site?
