Janice50
Apr 17, 2020Aspirant
wifi extender will not recognize router network password
My wifi extender has been set up to my router. i can see the extension wifi in my drop down.When i click on it it asks for my router network password. when i enter this it says it is the wrong passwo...
Apr 17, 2020Guru - Experienced User
Did you set it up via wps? if so, factory reset the extender and re-install it using the installation wizard and not wps.
Not all router makers code wps the same.
Janice50
Thanks ,I have tried so many ways Not sure I have the installation wizard. It says log in to Wi-Fi using the netgear_ex ? But I don't get that option in my Wi-Fi networks?
- Janice50Apr 17, 2020AspirantMy extender was actually connected to my router I checked with my supplier but I it still asked for router password?
- plemansApr 17, 2020Guru - Experienced User
Janice50 wrote:
My extender was actually connected to my router I checked with my supplier but I it still asked for router password?Again, if they connected it via wps, its might not have setup properly.
Factory reset the extender and then follow the install guide for using the install wizard. Don't use wps.
- Janice50Apr 17, 2020AspirantOk. Thanks. Will give it a go tomorrow.
Jan
