AliP1
Jan 09, 2020Aspirant
WiFi extender WN3000RPv3
I am having trouble connecting devices to the WiFi extender. I have gone through set up multiple times, got the extender connected to the router successfully with all green lights, but when I try to c...
- Mar 30, 2020
Hi Ali, thanks for checking back.
Page 38 of the user manual linked below provides the steps on how to reset the extender.
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_25Aug2015.pdf
Once this is completed, you can go through the setup/installation as described on the installation guide linked below as well as on the manual linked above.
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_QSG_17Aug2015.pdf
Once completing the setup, check if you are able to connect your devices to the extended network and see if they can go online. If not, the next step would be to use a device that is already connected to the main network (mobile, PC, etc.) and access the web UI (user interface) of your main wireless router. Once you are there, you can check for the attached devices and see if the extender is listed as one of them. If yes, it should have an IP assigned to it. Use that IP address and type it on the address bar to get to the web UI of the extender.
Dexter
Christian_R
Jan 16, 2020NETGEAR Employee Retired
Hi AliP1,
Please factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
Christian
