bluesparkuk
Dec 17, 2019Follower
wifi extender
hi firstly thanks for any help received, i am looking for a wifi extender, that can connect with a wifi password only, its for taking on holiday, the apartment i go to in Crete i am always on the top ...
Dec 17, 2019Guru - Experienced User
Most if not all of netgear's wifi extenders have the option to use the smart installation wizard. You dont need access to the router to use this method. All you need is the ssid and password. If you visit a extenders support page, it'll have both a manual that walks you through the manual install as well as usually a video showing you how. I never use wps and prefer to use the manual route as it tends to work better in my experience
