Pianoeliz
Sep 24, 2020Tutor
WIFI extender
Our range extender works well after it is set up, but after a period of several hours, when we try to connect on both bands, 2.4. And 5G, we get the message "no internet connection." When we unplug...
Pianoeliz
Sep 24, 2020Tutor
Spectrum internet and a UBEE router. Firmware is up-to-date Netgear. We installed the extender just a few days ago.
Sep 25, 2020Guru - Experienced User
Pianoeliz wrote:Spectrum internet and a UBEE router.---which ones?
Firmware is up-to-date Netgear.---numbers help more than the latest.
details help more than generals. When asked about modem/router when you say spectrum/ubee its like a mechanic asking which car you have and saying chevy. It doesn't help the situation as there's many models and each have their own issues.
- PianoelizSep 25, 2020Tutor
Ubee DVW32CB.
Firmware Version: 9.40.2111
Netgear extender firmware version 1.02.2.152
- plemansSep 25, 2020Guru - Experienced User
Did you install using the wps method?
Or using the installation wizard?
Have you given the extender a static ip address in the ubee?
The WPS button on the router did't work, so I used the wizard.
No I haven't set a static IP address, and don't know how to. Maybe that is the problem?
