browne25100
Nov 13, 2020Aspirant
Wifi extender
I am looking for a new wifi range extender to help with the zoom and Teams calls. I live in a townhouse with concrete floors. The router is in the basement so having trouble gettig a good signal on...
browne25100
The router from the cable company is hard wired in the basement. Are you suggesting mounting the extender to the router and connect via ethernet in the basement. Do to it being concrete floors, I don't have a way to get ethernet out of the basement to the first floor.
Nov 13, 2020Guru - Experienced User
I was just seeing if you happened to have ethernet ran throughout the home. Some do. There was even a period where homes used cat5/5e cable for the phone lines. They could be easily converted from phone jacks to rj45.
If not, you could always try coax moca adapters or powerline adapters.
