Vivekiyer110
Jan 04, 2021Follower
Wifi Extender
My extender just shows both the power LED and 2.4 GHz lED on solid even though I have both 2.4 & 5G. On trying to extend by pressing the WPS button the light keeps blinking and doesnt go solid. Also...
Jan 04, 2021Guru - Experienced User
What actual router do you have? (Model)
have you tried a factory reset and then reinstall using the installation assistant? Don't use wps.
