Mcerasuolo
Aug 16, 2022Follower
Wifi Extender
I just bought a house and I have a detached garage. I need wifi out there. I have xfinity internet 1.2 gig modem. The gargae is about 15 yards from the modem. But I have one pod from xfinity that's about half way. And still low to no wifi out in garage. What can I use that'll work?
any chance you can connect the 2 via ethernet?
Reason I ask is external walls tend to be made from materials that block wifi well.
If you can hardwire them in, thats the ideal solution
Mcerasuolo wrote:
I have xfinity internet 1.2 gig modem.It might help if you told people what this modem is. Perhaps it is a modem/router. That will affect what will work with it.
Try plugging your needs into the filters on the product pages:
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
