Thanos21's avatar
Thanos21
WiFi Extender
I live in a three story house and I am trying to get full coverage. What WiFi extender can be used with a Nighthawk AX12. The unit is overkill for my internet but I could not resist the price.
  • plemans's avatar
    Nov 24, 2022
    The interior walls are cinder block? Or just the exterior.
    the RAX120 is a pretty rock solid router. If you can centrally locate it, it should cover 3000sqft without much issues.
    Do you have ethernet ran throughout the home? if so, you could connect the Pace gateway in router mode, connect that to the switch, and then connect the RAX centrally located in AP mode.
