Thanos21
Nov 21, 2022Aspirant
WiFi Extender
I live in a three story house and I am trying to get full coverage. What WiFi extender can be used with a Nighthawk AX12. The unit is overkill for my internet but I could not resist the price.
- Nov 24, 2022
The interior walls are cinder block? Or just the exterior.
the RAX120 is a pretty rock solid router. If you can centrally locate it, it should cover 3000sqft without much issues.
Do you have ethernet ran throughout the home? if so, you could connect the Pace gateway in router mode, connect that to the switch, and then connect the RAX centrally located in AP mode.
henrymamar
Nov 14, 2023Aspirant
Consider a reliable extender like Netgear Nighthawk X6S for optimal coverage with your Nighthawk AX12. It complements your high-performance router and ensures seamless connectivity throughout your three-story house.
