lotrcsafan1989
Nov 07, 2023Aspirant
WiFi Extender
About a year ago I bought a WiFi extender and I just began to use it again after having no need for it for quite a while. While setting it up, I got a good connection to it for about a day before it w...
- Nov 08, 2023
lotrcsafan1989 wrote:
I'm using the AC1200 WiFi Range Extender EX6110. I've set it up using the guide from the website---What guide? There's multiple. And did you set it up in mesh or standard with a separate ssid
and it's connected to a Spectrum router,--which one? Some of theres had/have issues with extenders
and the extender itself is exactly at a halfway point between where I need to connect and the router---doesn't mean its in a good spot. Halfway could be to far. Or to near if in mesh. Its also important for whats in between. The walls themselves can block wifi if they're plaster lathe. Or hvac in the walls. Sometimes a lateral move can help to remove those blockages. Its why we ask how far, whats between.
. I updated the firmware to the latest (that I know of)---so what version is it on?
but it still gives me a security warning a d doesn't let me connect to the network.---whats giving you a security warning? And what is that warning?Details are key. Troubleshooting over a forum isn't easy so the more detailed you are, the better we can help you. You might not think its important (and it might not be) but many times, the little things are what cause the issues.
Nov 08, 2023Guru - Experienced User
What extender model do you have?
Firmware on it?
What router is it connected to?
How far from the router are you and what is in between the 2 devices?
What method of setup did you use? (wps, installation assistant, app, etc)
- lotrcsafan1989Nov 08, 2023AspirantI'm using the AC1200 WiFi Range Extender EX6110. I've set it up using the guide from the website and it's connected to a Spectrum router, and the extender itself is exactly at a halfway point between where I need to connect and the router. I updated the firmware to the latest (that I know of) but it still gives me a security warning a d doesn't let me connect to the network.
- plemansNov 08, 2023Guru - Experienced User
- lotrcsafan1989Nov 08, 2023AspirantSo sorry for the vagueness of it all! I'm not very tech savvy, but to answer a few of your questions: the firmware I downloaded is the latest one, which to my knowledge is 1.0.1.80 for the extender itself. The router is a Spectrum WiFi6 router SAX1V1K router. The signal isn't being blocked by any interference because without the extender I can get to the halfway point without losing signal but the further away I am, the less strength the signal has (obvious, I know). The guide I set it up with is the default guide that it gives me to use when I first open the box, the NetGear Setup Wizard at the extender IP address. The warning it gives me says that anything I connect to will not be secure, and thus does not act like I'm actually connected because it says my certificate has expired.
