Laexpo
May 13, 2020Follower
WiFi extender/model# EAX20
Can't connect
Oct 20, 2020Guru - Experienced User
Alphonz If you'll start your own thread, I'll be happy to help. this keeps your info seperate from the OP's info to reduce confusion.
Laexpo some more info is needed for your issue.
what router are you connecting to?
firmware on the extender?
Did you set it up using wps or using the installation assistant?
Alphonz
Oct 20, 2020Initiate
Hi the Router is Az-tech which is provided by the service provider. The extender firmware is the latest on the Netgear support web .36. The setup was via the Nighthawk app and mywifiext with the pc tethered to the extender. Switched between both multiple times. Also checked the router is not bridged’ mode.
- plemansOct 21, 2020Guru - Experienced User
Alphonz wrote:
Hi the Router is Az-tech which is provided by the service provider. ---which one? A model number helps. Some routers are locked down or designed for mesh and need certain seetings changed/disabled to function with extenders. Its why we ask for the router when troubleshooting. AZ-Tech is like telling a mechanic when he asks for car model that its a Ford. They make many different models and each is different. The extender firmware is the latest on the Netgear support web .36. The setup was via the Nighthawk app and mywifiext with the pc tethered to the extender. Switched between both multiple times. Also checked the router is not bridged’ mode.
