TheChosenSphinx
May 05, 2017Follower
Wifi Extenders and Captive Portal
Can these Wifi Extenders receive, amplify and broadcast/transmit a signal from a public wifi network that is behind a Captive Portal with Web Authentication? 1. NETGEAR Nighthawk AC1900 Desktop W...
jforten420
Oct 16, 2023Aspirant
NETGEAR WiFi Range Extender EX2800 - WiFi Extender AC750 allows login through a captive login portal.
Oct 21, 2023Guru - Experienced User
You need something that supports wisp mode.
Check into gl.inet's line of travel routers. They have wisp mode.
