berlin433
Feb 11, 2025Aspirant
Wifi extenders can't connect to new Wifi router
I had to have my whole Verizon FiOS setup upgraded: new ONT, new cables run, new set top boxes and, most importantly, a new Wifi router, a Verizon CR1000B. I have two Netgear AC1200 wifi range exten...
Feb 12, 2025Guru - Experienced User
the CR1000B uses verizons version of mesh. its called a self organizing network. It causes havok with extenders.
Try disabling this on the CR1000B and then use the installation assistant on the extender.
If you set it up using the push button WPS option, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
