AGM17's avatar
AGM17
wifi extenders compatible with Netgear ADSL2 modem routers
What wifi extender will work with a Netgear ADSL2 modem from frontier?   It's a model D2200D.
  • plemans's avatar
    any of netgears extenders should work.
    the only thing to keep in mind is the D2200D is an older dsl gateway thats only single band. Meaning it only has a 2.4ghz band.
    are you needing faster speeds? or more coverage?
    Adding a router in access point mode or even upgrading the gateway might be more beneficial than adding an extender in some circumstances.
      • plemans's avatar
        pretty much any of netgears extenders would work for adding coverage.
