Winetime
Mar 03, 2020Follower
WiFi extenders compatible with Vodafone Hub
Hi I am having issues finding a WiFi extender that works with my new Vodafone Hub! They all worked previously with my Sky Hub but since changing providers no joy. Have spoken with Vodafone and they sa...
DexterJB
Mar 05, 2020NETGEAR Moderator
Hi Winetime, what is the model of your NETGEAR extender? Are you able to complete the setup without any issue?
Dexter
DexterJB
Mar 09, 2020NETGEAR Moderator
Hi Winetime, I would like to follow up and check if you are still experiencing the issue.
Dexter
- Bg2020Mar 15, 2020TutorWe are having this exact problem since switching to Vodafone. The extender worked fine with the old TalkTalk router. The extender is the 32000 model. I think. Anyone got any ideas to help us? Thanks
- DexterJBMar 16, 2020NETGEAR Moderator
Hi Bg2020, please provide the exact model number of the extender. Also, have you gone through resetting the extender and setting it up with your new router? Are you encountering any error message during the process?
Dexter
- Bg2020Mar 19, 2020TutorHi Dexter thanks so much for replying. The model is N300 EX700.
We have tried setting it up again (numerous times) and although it appears to work and we can see the new WiFi (_EXT) as an available network none of our devices can connect to it. We just get the incorrect password error. We are using the correct password. I have also tried splitting the WiFi on the main router but this did not help, same error. Any help or recommendations of extenders compatible with Vodafone router much appreciated. Especially as my children will be at home full time from Monday as all the schools are closing!
