Winetime
Mar 03, 2020Follower
WiFi extenders compatible with Vodafone Hub
Hi I am having issues finding a WiFi extender that works with my new Vodafone Hub! They all worked previously with my Sky Hub but since changing providers no joy. Have spoken with Vodafone and they sa...
DexterJB
Mar 30, 2020NETGEAR Moderator
Hi all, apologies for the delayed response. If the setup process completes successfully, please try accessing the web UI of the extender via the assigned IP from the router. Once on the extender UI, please make sure that the password saved is correct or have it modified and see if the devices will connect.
Dexter
CalmWraith
Apr 01, 2020Aspirant
Sorry. What? I'm having the same problem. Could you give that answer again in layman's terms?
Thanks
Paddy
- R0dn3yApr 21, 2020Tutor
Yesterday started to use Vodafone hub and cannot get the extender to work, like a few other users, what it the solution?
