leehop71
Apr 06, 2019Aspirant
Wifi Extenders That Do Not Decrease Speed
Are extenders that DO NOT decrease speed and actually work?
leehop71
pleman,
It looks like these are 3 affordable options that would work, although I definitely do not want overkill.
BTW, when everything comes in, I will have a Ring Doorbell 2, Spotlight Cam in the front of the house, a Stickcam on the sides of the house and the back, Floodlight Monitors in the back, and Spotlight monitors on each side of the house, and the lights will work off a bridge from Ring.
It looks to me, even if I use the powerline, I can plug the bridge into that and have it closer to the lights.
https://www.amazon.com/NETGEAR-PowerLINE-1000-802-11ac-Gigabit/dp/B01929V7ZG
Apr 06, 2019Guru - Experienced User
It looks like 2 of them have items in the amazon warehouse for a cheaper price if you were looking. I've had good luck with amazon warehouse products and they have a 30 return on warehouse items. Just a thought. All of them should be decent options for what you're trying to accomplish. I tend to go overkill but thats just a personal preference. :) Hope it works great for you!
- leehop71Apr 06, 2019Aspirant
Thanks again for your patience and understanding. I could plug my bridge into the extender, correct?
