jtswat285
Dec 15, 2020Tutor
WIFI Extenders
Can both extenders be used in tandem?
Dec 15, 2020Guru - Experienced User
which extenders? a model helps?
And how do you have them setup?
I would highly recommend against daisy chaning them.
Daisy chain: router---->extender------>extender
star would be prefered.
star: extender<-------router------>router
i usually recommend to people if they're needing more than 1 extender to move to a full mesh system like orbi versus trying to juggle mutliple extenders.
- jtswat285Dec 15, 2020Tutor
Thank you for the feedback. I have a 6150 and a 6120. I set them up using the WPS.
- plemansDec 15, 2020Guru - Experienced User
Are you having issues setting them up? and if so, what are the issues?
No, my issue is that the 6150 seemed to fall offline about once a week. It is about 4 yeas old so I purchsed teh 6120 to use as a backup. I have them both plugged in. My Ring cameras are linked to them and they often just stop working. I unplug the extender and plug it back and that usually fixes the issue. Now that is not even working. The extenders link to my phone but then when I try to access the internet, it wont.
