jtswat285
Dec 15, 2020Tutor
WIFI Extenders
Can both extenders be used in tandem?
Dec 15, 2020Guru - Experienced User
What router is it connected to?
When 2 devices are failing in the same route, it points to something else being the issue. The router is the backbone of the system and if its lease is expiring, it could be causing the issue.
Did you set them up using wps?
If so, try factory resetting and reinstalling using the installation assistant. don't use wps.
jtswat285
Dec 15, 2020Tutor
The router was just replaced by Xfinity last week. They worked for a few days and then the problem started. I will try using the install asst.
Thank you.
