Michele16's avatar
Michele16
Follower
Feb 02, 2021
WiFi extenders
Help!! I’m with virgin , WiFi not reaching back bedroom upstairs , which WiFi extender would be best for that back bedroom? In other bedroom my son has hard wired his computer to another extender n( net gear) . Thanks in advance .
1 Reply
  • plemans's avatar
    the best? I'd recommend one of the triband extenders.
    But there's a bunch of single/dual band extenders that might work for your purpose as well.
    you can go through them https://www.netgear.com/home/wifi/range-extenders
    You can sort by features that you want.
    something else to keep in mind.
    1. i usually recommend people move to a mesh system like orbi if using multiple extenders.
    2. virgin used to send out extenders for free to people with issues. not sure if that's still the case. might be worth checking into
