zernichter
Aug 18, 2023Follower
Wifi Extener Access Control - I am confused....
Hello guys, i got a very stange problem, maybe I understand something wrong but its very confusing... I bought a Netgear Essentials WiFi 6 (WAX206) Wifi Router, and everything works fine, I enabled ...
jeanjee
Aug 20, 2023Aspirant
It appears there's a confusion with your Netgear WiFi setup. Your Netgear Essentials WiFi 6 (WAX206) router's Access Control doesn't seem to affect the AX1750 WiFi Mesh Extender (EAX18). Unlike what you expected, the router's Access Control doesn't sync with the extender. Additionally, the EAX18's Access Control only allows you to deny access for new devices by manually checking the connected device list. This setup seems counterintuitive, as the expected behavior for Access Control is usually to block new devices by default. It's best to review the user manuals or contact Netgear support for clarification on this setup quirk.
