misterbojangles
Jul 16, 2024Initiate
WiFi extension options
I am looking for recommendations for compatible add-ons to improve/extend my network with regards to signal strength & speed. I am using a RAXE500 router with CM2000 modem connected to a solid reliab...
- Jul 17, 2024
You're a little caught. The reason I say that is the RAXE500 is a rock-solid router and expensive, and I don't recommend more than 1 extender before switching to a true mesh system.
So you have a couple of options. I'd recommend that you buy them from somewhere with a generous return policy so you can return/exchange them if it doesn't work out.
1. Try a single extender like the EAX80. It might provide the additional coverage you need. Sometimes to much coverage is as bad as not enough.
2. Return the RAXE500 or sell it and purchase the mesh system with 2 satellites you want.
3. Add a mesh system to the RAXE500 as a separate network. If the peripheral devices aren't needing "max" speed, you could always pickup something like the Orbi RBK753/763 system and run the orbi in access point mode. Its a cheaper system so won't have the max speed of the RBK963 or RBK973 but is a fraction of the price. Prime day has new ones cheap and reburbed even cheaper. That'd let the peripheral still have coverage and be able to use the RAXE500.
If you go that route, set the orbi with a different ssid and on different channels than the RAXE to prevent interference.
Jul 17, 2024Guru - Experienced User
misterbojangles
Jul 17, 2024Initiate
Thank you plemans! That was very helpful and insightful. I think I’ll go with the EAX80 to avoid some of the hassle of trying to tweak the network. Now all I have to do is talk myself out of prime deals for a just-in-case Mesh.
Thanks again!
Thanks again!
