Loganwildman
Aug 08, 2016Aspirant
Wifi extension to metal buiding
I have a metal shop that I am trying to get internet into. I currently have a Nighthawk 7000 (AC1900) in the house, and a Belken extender in the shop positioned close to the garage door window (appro...
DarrenM
Aug 10, 2016Sr. NETGEAR Moderator
Hello Loganwildman
The best way to get wifi out to the shop would be powerline but that requires your shop and house to use the same power circuit which sounds doubtful since you may be using big equipment out there. Its really hard to say if the EX7000 would fix the issue with all the variables that could be affecting the wifi signal. Have you tried to adjust the wireless channel on the R7000 to see if you can get a better signal you can use phone apps to help find the best channel to use with the least amount of interfearance. Our app is on android and is called Netgear Wifi analytics.
DarrenM
Loganwildman
Aug 10, 2016Aspirant
Thanks for the reply Darren. Power isn't an option as the shop is feed by another meter. What about replacing one of the 3 antenna's with a Netgear outdoor antenna's. If that would be ok for the device, it would solve my issue as getting outside of the metal building would be sufficent to get a better signal.
- VE6CGXAug 10, 2016Master
If you extend coax connection to locate antenna outsie, length of coax attenuate RF signal to a degree. Care to run a cable to shop? That if possible will be best solution for reliable access to the 'Net.
- LoganwildmanAug 11, 2016Aspirant
Running a cable would definitely be the way to go, but would require renting a trencher and purchasing conduit and underground rated cable, ie $$$$$. That is why I am looking at wireless first.
- VE6CGXAug 11, 2016Master
Then you can use weather proof outdoor gain antenna equipped wireless repeater. Maybwe Ubiquiti product.
