Loganwildman
Aug 08, 2016Aspirant
Wifi extension to metal buiding
I have a metal shop that I am trying to get internet into. I currently have a Nighthawk 7000 (AC1900) in the house, and a Belken extender in the shop positioned close to the garage door window (appro...
Loganwildman
Aug 10, 2016Aspirant
Thanks for the reply Darren. Power isn't an option as the shop is feed by another meter. What about replacing one of the 3 antenna's with a Netgear outdoor antenna's. If that would be ok for the device, it would solve my issue as getting outside of the metal building would be sufficent to get a better signal.
VE6CGX
Aug 10, 2016Master
If you extend coax connection to locate antenna outsie, length of coax attenuate RF signal to a degree. Care to run a cable to shop? That if possible will be best solution for reliable access to the 'Net.
- LoganwildmanAug 11, 2016Aspirant
Running a cable would definitely be the way to go, but would require renting a trencher and purchasing conduit and underground rated cable, ie $$$$$. That is why I am looking at wireless first.
- VE6CGXAug 11, 2016Master
Then you can use weather proof outdoor gain antenna equipped wireless repeater. Maybwe Ubiquiti product.
