Loganwildman
Aug 08, 2016Aspirant
Wifi extension to metal buiding
I have a metal shop that I am trying to get internet into. I currently have a Nighthawk 7000 (AC1900) in the house, and a Belken extender in the shop positioned close to the garage door window (appro...
VE6CGX
Aug 10, 2016Master
If you extend coax connection to locate antenna outsie, length of coax attenuate RF signal to a degree. Care to run a cable to shop? That if possible will be best solution for reliable access to the 'Net.
Loganwildman
Aug 11, 2016Aspirant
Running a cable would definitely be the way to go, but would require renting a trencher and purchasing conduit and underground rated cable, ie $$$$$. That is why I am looking at wireless first.
- VE6CGXAug 11, 2016Master
Then you can use weather proof outdoor gain antenna equipped wireless repeater. Maybwe Ubiquiti product.
