rongo69
Nov 27, 2021Follower
wifi help area coverage
Problems i'm extender is to far from house to give me good wifi coverage for my firestick tv. I get the internet thru extender from the source router 300-400 ft away. Then i have a cable out the bac...
Nov 28, 2021Guru - Experienced User
A bit confusing as what you're trying.
If you're home is that far from the internet source, I'd be looking at a point to point system versus using an extender. They'd have much higher throughput so the base speed coming into your home is faster.
Is that the issue you're having?
Reason I say this is if you're speeds coming into the home are to low, it doesn't matter what router you have in the home, it isn't going to increase your speeds.
