marylparkr
Apr 18, 2020Aspirant
Wifi Mesh Extender AC1750 - Placement
I just purchased an extender for my home. My router is on the main floor of my home. I have a basement that I would like to access the extender for a ring camera and smart tv. Should I place the e...
marylparkr
Ok will do. Thank you for the response. May I ask you another question? Is there a reason my Iphone would not automatically connect with the best wifi choice in my home? It has really stopped working well.
Apr 18, 2020Guru - Experienced User
Which extender are you using?
And what router are you using?
- marylparkrApr 21, 2020Aspirant
Model EX6250 - AC1750 Extender
The Router is from Spectrum
