d_train
Jan 05, 2022Aspirant
Wifi Mesh Extender ex6250 losing internet connection (with vodafone NBN Modem)
Hi All, I was wondering if I could get some help on this. I bought a ex6250 last month and installed it to extend my wifi signal from my modem/router downstairs at my house. The modem/router ...
d_train
Jan 08, 2022Aspirant
Thanks for the reply mate, its the latest firmware (v1.0.3.30)
I've reset it a few times and there hasn't been any improvements. Been speaking to vodafone support but they've been hopeless.
I feel that its a setting that needs to be made from the vodafone modem to allow the internet to stop dropping out.
Jan 09, 2022Guru - Experienced User
what vodafone modem/router is it?
- d_trainJan 09, 2022Aspirant
Its branded under Vodafone and is their "Hub 2.0". i believe it could be made by Hwawei as I had their first model hub and that had Hwawei somewhere in the packaging whereas this one didn't.
details are in the link below:
https://www.vodafone.com.au/support/nbn/wi-fi-hub?accordion-id=fibre-to-the-premises-%28fttp%29-
Thanks again for your help
- plemansJan 09, 2022Guru - Experienced User
If you look on the vodafone forums, you see a ton of issues trying to use extenders with the vodafone routers. I haven't seen a good method that allows them to connect other than hardwiring in an extender and using it access point mode.
- d_trainJan 10, 2022Aspirant
Darn that's sad to hear :(
Wish there was a way to make it work, the wifi signal is so crap from the vodafone router
