KellyW0466
Nov 27, 2021Follower
WiFi Mesh Extender
Why does some of my devices show 5.0 ghz and others show 2.5 ghz on the mobile app? How do I connect all my devices to show 5 ghz?
Nov 28, 2021Guru - Experienced User
If you're using the "One Wifi" feature, it allows devices to switch between the 2.4ghz and 5ghz as needed.
You can always disable that and choose which band to connect your devices to.
