italianbeef
Feb 06, 2020Star
Wifi mesh where I can manually configure the mac address?
Hey everyone,
I'd like to install a wireless mesh network, but my ISP requires that my router to be set to a specific MAC address. Anyone know of a mesh network that supports this? Does the MK62 support this?
I believe I can also use my existing router, disable the wireless, and configure the mesh network to run in bridge mode. I believe?
Thank you!!!!
- DexterJBNETGEAR Moderator
Hi italianbeef, welcome to the community! Most, if not all, WiFi Mesh system from NETGEAR work with any ISP and that includes the MK62. Are you referring to a static IP address as your subscription? Which ISP is it? Is it using cable, DSL, Fiber or something else?
Dexter
DexterJB Just wondering if you were able to confirm this? Thank you!!!!!
