weedkill3
Mar 25, 2020Aspirant
Wifi Range Extender AC1200
Hello ,
I bought and setup the AC1200 extender thru the "Netgear Installtion assistant". THe good new is the extender works and the extender wifi network shows up.
My question is, on the physical extender itself, all the LED are green, EXCEPT for the WPS, its blank.
As of right now, I have no password setup yet. Is that why the WPS is not lit up?
The wps light isn't lit because you didn't set it up via wps. That's all.
Not an issue if everything is working as it should. Mine are never lit because I rarely use wps.
- plemansGuru - Experienced Userand because you didn't set security. sorry, typing to fast and hit enter to early.
I'd recommend wpa2 security for it
