Imhoff05
Dec 04, 2022Follower
Wifi Range Extender AC750 Ex3110
I cannot get the extender to connect to the router. It is right next to router. I have tried turning it off and on, and resetting both the router and extender. Since it will not connect to the router ...
michaelkenward
Dec 05, 2022Guru - Experienced User
What router is this? What happens when you try?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
