simonadams
Mar 04, 2012Aspirant
Wifi Range Extender Drops Connection
I have a WN2000RPT and it works fine apart from permanently loosing connection to the router after about a day. The top light on the front goes orange and it is completely useless until you power cyc...
simonadams
Mar 09, 2012Aspirant
P.S. I set it to "54g performance". It may not be the solution for everyone, but it is strange that LRS is set as default by Sky, as its not the manufacturers recomended setting...
