MacNDyl
May 17, 2020Aspirant
Wifi range extender EX6110 wont connect to my smart tv. Keeps saying its the wrong password.
So I just got this new extender and Its working perfectly fine for everything, laptop, xbox, phone, but it wont work for my smart TV. Its a sony smart TV. It keeps saying that the password is incorrec...
May 18, 2020Guru - Experienced User
did you setup the EX6110 via wps?
If so, I'd reset it and try the install via the installation wizard and now wps.
What router is it connecting to?
Firmware on it?
- MacNDylMay 22, 2020AspirantNot set as a WPS. Unsure.
- plemansMay 22, 2020Guru - Experienced User
I mean did you set it up using the wps button? its a method of setting that is pretty easy but different manufacturer's don't always code it the same. So if there's issues, then you want to use the installation assistant.
