MacNDyl
May 17, 2020Aspirant
Wifi range extender EX6110 wont connect to my smart tv. Keeps saying its the wrong password.
So I just got this new extender and Its working perfectly fine for everything, laptop, xbox, phone, but it wont work for my smart TV. Its a sony smart TV. It keeps saying that the password is incorrec...
MacNDyl
May 22, 2020Aspirant
Not set as a WPS. Unsure.
May 22, 2020Guru - Experienced User
I mean did you set it up using the wps button? its a method of setting that is pretty easy but different manufacturer's don't always code it the same. So if there's issues, then you want to use the installation assistant.
