Timbo6459
Jan 08, 2020Aspirant
Wifi Range extender EX6110
I am trying to set up the range extender with it plugged into a socket less than 1m away from the BT Hub 4-S8FT but the device light will not light (the other three all light). It appears that the ex...
- Jan 08, 2020
The device led is for when a device such as phone/tablet/etc is connected to the extender. if the extender is only 1m away from the router and using the same ssid as the router, devices are going to connect to the router and not the extender.
Jan 08, 2020Guru - Experienced User
- Timbo6459Jan 08, 2020Aspirant
Thanks for your help
