ATM4
Aug 25, 2022Aspirant
Wifi Range Extender Factory Reset Not Working / All Lights On
Good Evening - I have a Netgear AC 1900 Wifi Mesh Extender that i purchased over a year ago, I used this product once for a shipping device that required it and only used it for a couple of days....
Aug 25, 2022Guru - Experienced User
1. What device do you have? AC1900 is a speed, not a model
2. you bought it over a year ago? Most area's are only a year for warranty and 90 days for support. You're outside of both so I can understand the charging you for assistance
3. what color are the leds?
4. if you hardwire into the device, does it get a connection to the extender?
ATM4
Aug 26, 2022Aspirant
Thanks for the response,
1)I have the EX6400v2.
2) Understandable, I just would've thought they could help more than just sending me instructions on how to factory reset the device after i said that was not working.
3) WPS is green, power is orange. Router and Client LED are both orange with the arrows point to each blue.
4) Nothing changes when I hardwire the device to the router, the LED's stay the same. Can't reset etc.
Thanks again for the response and any suggestions you may have would be greatly appreciated!
- plemansAug 26, 2022Guru - Experienced User
When you push and hold reset for 7-15 seconds while its powered on, do the led's doing anything?
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash- ATM4Aug 26, 2022Aspirant
No, they stay lit up when trying to factory reset.
I do not have Windows, but can download boot camp on my mac to give it a try.
Thanks for your help,
