RP10
Jul 22, 2020Aspirant
Wifi Range Extender N300 Client Link LED only green when I'm on device
Good Afternoon All, Hoping someone can help me understand my wifi extender a bit more. Why is it that my client LED is only Green when I am using my cellphone which is the device I used to set up...
- Jul 22, 2020
the client light only lights up when a device is connected to the extender. The color it lights up indicates the signal between the extender and whatever is connected to it.
firmware does occasionally need updating. you can check which version you're on and compare it to the support sites version.
https://www.netgear.com/support/product/WN3000RPv3.aspx
All devices don't need to be on the extender and I'd actually recommend against this. Reason why is extenders are only designed to give you some extra distance or cover a dead spot. They're actually going to be slower than your router is. And here's why. An extender has to recieve a signal and then retransmit it. And it can't do both at once. (except the tribands) so they cut your speed/throughput in half. Meaning they're going to be slower than a direct connect to the router unless they're out of range of the router or in a deadspot. Then the extender will be better.
Jul 22, 2020Guru - Experienced User
RP10
Thank you so much I appreciate the response!
Would you happen to know why my main network now shows not being connected to the internet? Did I do something wrong in connecting the extender. I figured the extender was for devices in dead spots but now I cannot connect to my main network only thing that works is the extender network?
- plemansJul 22, 2020Guru - Experienced User
did you set it up using wps or the installation wizard? I'd try rerunning setup using the wizard. Not all device makers code wps the same and it can occasionally cause issues on a network.
