RP10's avatar
RP10
Wifi Range Extender N300 Client Link LED only green when I'm on device
Good Afternoon All,   Hoping someone can help me understand my wifi extender a bit more. Why is it that my client LED is only Green when I am using my cellphone which is the device I used to set up...
  • plemans's avatar
    Jul 22, 2020
    the client light only lights up when a device is connected to the extender. The color it lights up indicates the signal between the extender and whatever is connected to it.
    firmware does occasionally need updating. you can check which version you're on and compare it to the support sites version.
    https://www.netgear.com/support/product/WN3000RPv3.aspx
    All devices don't need to be on the extender and I'd actually recommend against this. Reason why is extenders are only designed to give you some extra distance or cover a dead spot. They're actually going to be slower than your router is. And here's why. An extender has to recieve a signal and then retransmit it. And it can't do both at once. (except the tribands) so they cut your speed/throughput in half. Meaning they're going to be slower than a direct connect to the router unless they're out of range of the router or in a deadspot. Then the extender will be better.
