Stee
Apr 16, 2020Aspirant
Wifi range extender N300
Buongiorno, Ho acquistato wifi range extender N300 per amplificare il segnale wifi in tutta la casa. Peccato che il led client non si sia mai acceso e non consente il log alla rete nuova_EXT Consig...
Apr 16, 2020Guru - Experienced User
Factory reset the extender. Push and hold reset while its powered on for 7-15 seconds.
Then re-run the installation and use the installation wizard and not using wps. Wps gets coded different between different manufacturer's and can create issues.
- SteeApr 16, 2020AspirantDone....but it doesn’t log the network
- plemansApr 16, 2020Guru - Experienced User
Stee wrote:
Done....but it doesn’t log the networkthis didn't help. it didn't explain what you did. "log the network" can be taken many different ways.
Please be precise in what steps you did, where the errors are, and whats going on. I'm not there to see so I can't help without details
- SteeApr 16, 2020AspirantOok...sorry <br>So...step By step<br>I swich on the extender<br>Open the network netgear_ext<br>Log to the browser mywifiext
<br>I find my homenetwork <br>Insert the correct psw...but i can’t log <br>( ACL is disable in my router) ...so i can’t continue <br>
