Stee
Apr 16, 2020Aspirant
Wifi range extender N300
Buongiorno, Ho acquistato wifi range extender N300 per amplificare il segnale wifi in tutta la casa. Peccato che il led client non si sia mai acceso e non consente il log alla rete nuova_EXT Consig...
Stee
Done....but it doesn’t log the network
Apr 16, 2020Guru - Experienced User
this didn't help. it didn't explain what you did. "log the network" can be taken many different ways.
Please be precise in what steps you did, where the errors are, and whats going on. I'm not there to see so I can't help without details
- SteeApr 16, 2020AspirantOok...sorry <br>So...step By step<br>I swich on the extender<br>Open the network netgear_ext<br>Log to the browser mywifiext
<br>I find my homenetwork <br>Insert the correct psw...but i can’t log <br>( ACL is disable in my router) ...so i can’t continue <br>- plemansApr 16, 2020Guru - Experienced User
<br>I find my homenetwork <br>Insert the correct psw...but i can’t log <br>( ACL is disable in my router) ...so i can’t continue <br>What router are you connecting to?
What do you mean by "acl is disabled in my router"?
What wireless security are you using on your router?
If you have any special characters/spaces in the router's ssid/password, remove them.
- SteeApr 16, 2020AspirantI have a modem/router adsl2+wifi wpa psk.
Acl is the acces control list....so the extender should be free to connect.
