Stee
Apr 16, 2020Aspirant
Wifi range extender N300
Buongiorno, Ho acquistato wifi range extender N300 per amplificare il segnale wifi in tutta la casa. Peccato che il led client non si sia mai acceso e non consente il log alla rete nuova_EXT Consig...
Apr 16, 2020Guru - Experienced User
Stee wrote:
Ook...sorry <br>So...step By step<br>I swich on the extender<br>Open the network netgear_ext<br>Log to the browser mywifiext
<br>I find my homenetwork <br>Insert the correct psw...but i can’t log <br>( ACL is disable in my router) ...so i can’t continue <br>
What router are you connecting to?
What do you mean by "acl is disabled in my router"?
What wireless security are you using on your router?
If you have any special characters/spaces in the router's ssid/password, remove them.
Stee
I have a modem/router adsl2+wifi wpa psk.
Acl is the acces control list....so the extender should be free to connect.
- plemansApr 16, 2020Guru - Experienced User
Stee wrote:
I have a modem/router adsl2+wifi wpa psk.------Not a router mode. If a mechanic asks what model car you have saying "its got an engine, 4 tires, and a steering wheel". Its not helpful. What manufacturer and model do you have?
Acl is the acces control list....so the extender should be free to connect.--------supposedly.You also put you're running wpa-psk. its an outdated wireless security. you should be running wpa2.
- SteeApr 16, 2020Aspiranthttps://img.tim.it/sdr/documenti/guide/Manuale_ADSL2_WiFi_N.pdf
Yes...it’s not the top
