MdeM
Dec 04, 2015Follower
WIFI range Extender WN3000RP-100PAS
HI I bought a new WIFI range Extender WN3000RP-100PAS Can you tell me if that "WIFI range Extender WN3000RP-100PAS" will be good to use the connection wifi 802.11 ac of my airport extreme ...
nhann
Dec 04, 2015NETGEAR Employee Retired
Hi MdeM,
Yes, the WN3000RP will work with your ac router. However, the WN3000RP only broadcasts WiFi up to 300Mbps (wireless-n).
Please see the datasheet:
http://www.downloads.netgear.com/files/GDC/datasheet/en/WN3000RPv3.pdf
